Fuel pump priming but not pumping
I purchased the truck knowing it wouldn't run on it's own. It'll run if you pour gas in the throttle. It had no fuel pump when I got it. I just replaced the whole fuel sending assembly with one from MTS Company. When I turn the key to accessory, I hear the pump whine for a second or two, but when I turn the key, it'll sit there and crank. I unhooked the sending hose and put it into a container to see if it was even pumping out any fuel. It is not. How can my pump be priming but not pumping? Thanks in advance!
The ECM is not calling for had when cracking. TPS would be my first test.
