Looking for some options to replace the bed, wall, gate liner. Haven't been able to find anything for Comanche. Also, do they make ones that have openings on wall side to accommodate clamps for truck bed cover? Hope my question makes sense.
Sent from my SM-G935T using Tapatalk
Are you looking to replace the actual Comanche bed, or are you asking about a molded, drop-in bed liner?
Molded drop in liner only. The current one I got won't work because of the Downey truck bed cover that I'm installing. There is no way for me to clamp the railing. I suppose it would have to be a molded bed liner only.
are you simply missing the openings for the clamps?  you can drill those out yourself with a big hole saw. :L:
Yep that's going to be my first attempt. I got a dremel oscillating tool to try.
