onlyinacomanche Posted September 26, 2007 Share Posted September 26, 2007 Hey guys, so it's been awhile since I've been on here, I kinda come and go as my trucks running or the money is available to mess with it, but I have a quick question. When I lifted my truck and helped my dad with his lift on his YJ I had some problems getting the new springs back in using the coil spring compressors. I just rented a set from Autozone, maybe it's the crappy set I had but is there some trick to getting the springs in out out easily? A third of the time I worked on installing the lift I spent on trying to get the new springs back on. This may be a stupid question and there may be no easier way but I figured I'd hit you guys up and see if anyone has any tricks or anything. Thanks. -Will Link to comment Share on other sites More sharing options...
Pete M Posted September 26, 2007 Share Posted September 26, 2007 I used a bottle jack to force the arms down a bit further. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted September 27, 2007 Share Posted September 27, 2007 Disconnect the swaybar? I've fit 4.5" coils in with both control arms still attached without a spring compressor. I've fit 6.5" coils in with the lower control arms still attached without a spring compressor. Yes I know, coil rates play an effect, and that some 4.5" and 6.5" coils are the same length... Link to comment Share on other sites More sharing options...
pingpong Posted September 28, 2007 Share Posted September 28, 2007 If you disconnect everything attatched to the axle ( shocks, swaybars, and brakelines) There is only 2 things preventing you from swinging the axle down... One is the trac bar... the other is the driveshaft. I almost never use my coils compressor... tall jack stands (12 ton northern specials) and my hi-lift to pull springs.... Jack the truck up till the coils unseat.. support with stands and go to work Link to comment Share on other sites More sharing options...
