Yes. You just need the 4 wheel drive version of your trans, transfer case and the front axle that matches the gear ratio of the rear. Or you can upgrade to the AX5 5 speed with 4 wheel drive.
Also, the transfer case shifter, the shifter gate that bolts to the floor, and the bezel for the transfer case shifter opening in the console.
The best source is to pick up a complete Cherokee donor vehicle. Be sure it's a 2.5L, because you can't just bolt a transfer case to your existing transmission. You will need the 4WD transmission, and you'll only find the AX-4 or AX-5 behind the 2.5L (or the 2.8L V6).
