Gauges question
Hey fellas! So its about time to guve my interior some love so I'm planning on a 97+ dash swap, and then I came up with this idea for a new cluster setup.
https://www.jegs.com/i/JEGS/555/41290/10002/-1
With this to as well
https://www.autometer.com/jeep-tj-direct-fit-gauge-panel.html?utm_source=google_shopping&gclid=Cj0KCQiAno_uBRC1ARIsAB496IX0EsV4JSA5wCuEHb0OfepNnHWuwW5S-c7uIoAfzY-i68mvxa6mZeEaAvkDEALw_wcB&gclsrc=aw.ds
Si what do you guys think? Doable?
Crazy idea? Keep the oem ones?
Btw
1987 swb 4.0
4x4
All stock renix things
4 hours ago, krustyballer16 said:
I spent $1300 on gauges in my Cummins swap in the old style dash so this $450 set up doesn't seem too bad.
Do you need a new fuel sending unit to run that gauge or will stock sender work with that fuel gauge somehow?
Sent from my SM-G973U using Tapatalk
I was thinking sticking with the same one.
I mean a saw a post on Fb of a guy running something very similar to it.
He said everything was stock that you just need to "tap" into the sensor.
Makes me wonder tbh
