1987 Comanche SWB 2WD
4.0 / Peugeot BA10/5 / no t-case / 2wd front axle / D35 rear / Short
Build date: Unknown.  Sticker was removed or painted over
Current Location: Denver area
Status: Sitting for years, unknown running condition.  Looks to be stock drivetrain.
Notes: No notes yet really.  The bed is pretty well beat up.  Still straight-ish but it definitely took more than one hit and looks worse the closer you get.  Collision damage reported in 2012, it's probably been sitting for that long.
Current owner: Me.
Plans:  4WD conversion.  Switch over to AW4, Atlas transfer case, front Dana 44, rear Ford 9", front long arm kit, rear spring over, fenders cut and bump stops to fit 37's.
*A6 Seats - Vinyl High Back Bucket
-H9
APA MONOTONE PAINT PACKAGE
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
DDJ 5SPD MANUAL TRANS A881 (JA-41)
ERB ENGINE - 4.0L I6 MPI GAS
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JJA CIGAR LIGHTER - FRT COMP
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAF HIGH ALTITUDE EMISS CONTROL PKG
PA2 SILVER MET CLEAR CT PRIMARY PAINT - FA2
QA2 SILVER MET CLR CT SECONDARY PAINT - FA2
SBA POWER STEERING
TBG SPARE TIRE - COMPACT
WMC BASE WHEEL DRESS - UP (INCLS TRIM RING)
Build Date 4/2/87
Body Code TL61
  • 1 year later...
