blakews2217 Posted October 10, 2019 Posted October 10, 2019 First post here, Too dark right now for postures but will get them in the daylight tomorrow. Current location: Alton, Illinois. 4.0, BA10(sadly) np231, 2.5”? Lift. Guessing because I don’t know for sure. Picket seats, cloth interior. Will get build date in the morning if it’s still there. Now for the really bad. Rust. Lots of it. Someone cut a door pin out on the passenger side, and the metal surrounding it. So that’s a project. Floors are gone. Leaky gas tank, leaky brake lines and somewhere there is air getting into the clutch system. Traded my clapped out 2000 xj for it. Wish me luck with all the work. Will make a build thread when I get there. Sent from my iPhone using Tapatalk (fixed the vin, I'm just blind)
eaglescout526 Posted October 10, 2019 Posted October 10, 2019 As soon as the light comes back can you get a better look at your VIN? Parts catalogue and I say theres something off about you VIN, so I can't decode it
blakews2217 Posted October 10, 2019 Author Posted October 10, 2019 1 hour ago, eaglescout526 said: As soon as the light comes back can you get a better look at your VIN? Parts catalogue and I say theres something off about you VIN, so I can't decode it Got the VIN fixed, I'm blind.
eaglescout526 Posted October 10, 2019 Posted October 10, 2019 1 minute ago, blakews2217 said: Got the VIN fixed, I'm blind. Lol. Decode coming up!
eaglescout526 Posted October 10, 2019 Posted October 10, 2019 *W7 Cloth Lo-Back Bckt/Red Accent Seats -SA Charcoal 3LX ADA LIGHT PACKAGE ADL PACKAGE - 4X4 PROTECTION AGL Super Sport Group (SS/T) APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CAC BUCKET SEAT - LO BK CGW Air Bags - Front, Next Generation** CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&&&&&& REAR CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBF REAR BUMPER - STEP TYPE (BRIGHT) MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHM AUTO SPEED CONTROL NHQ Transmission Heater PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) YJP NEW VEHICLE SERVICE - WINDSOR Build Date:7/26/87 Body Code:JP62
blakews2217 Posted October 10, 2019 Author Posted October 10, 2019 Seems someone wanted the cluster with a tach bad enough to swap mine out, god knows how many miles are on it. its also got a sunroof but i can't tell if it was factory. my only sunroof experience is on the ZJs. thanks for the build sheet.
eaglescout526 Posted October 10, 2019 Posted October 10, 2019 Sun roofs are not a factory option for the MJ's. Possible dealer option but no documentation. No problem. But a lot of pre 89 sheets are slightly inaccurate and reuse some newer codes
blakews2217 Posted October 10, 2019 Author Posted October 10, 2019 it has a wood spacer in it so i doubt its a dealer add-on, but it looks some what well done. if it becomes a problem it will be replaced with steel and welded in. i have so much welding to do after i cut the rust out. the carpet is falling out of the passenger floorboard. better pics to come tomorrow.
eaglescout526 Posted October 10, 2019 Posted October 10, 2019 Add the fred flintstone floor to your build sheet.
jdog Posted February 24, 2021 Posted February 24, 2021 Selling Dealer: JIM THORNTON AMC/JEEP/RENAULT Ottawa, IL
