Swampy Posted October 3, 2019 Share Posted October 3, 2019 This might be a dumb question but can you change the 5th gear ratio on an ax15? The stock ratio is .79, which is a little too much for my 2.5 to push 35s. I was wondering if you could swap the ax5 5th gear ratio which is .83 I believe so it should help with 5th gear power for driving. I don't know if its even possible or if it'll ruin the reliability of the ax15. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 3, 2019 Share Posted October 3, 2019 (edited) I asked the same thing but the other way around. They are all gonna tell you no. I barked up that tree recently. Didn’t end well for being curious. Here's that tree. Edited October 3, 2019 by eaglescout526 Link to comment Share on other sites More sharing options...
omega_rugal Posted October 3, 2019 Share Posted October 3, 2019 if you have the equipment to make your own gears, i think not... Link to comment Share on other sites More sharing options...
Crash Posted October 3, 2019 Share Posted October 3, 2019 Need more gear, or just run it in 4th gear. Link to comment Share on other sites More sharing options...
