nknapp16 Posted September 26, 2019 Share Posted September 26, 2019 Replacing battery cables and refreshing connections, one of the connectors snapped off where the small positive cable off the battery connects to a bolt. I can only find it's called the PDC, but can't find a replacement. Any ideas, photo attached Link to comment Share on other sites More sharing options...
Big Dan Posted September 26, 2019 Share Posted September 26, 2019 It's called a starter relay Sent from my Pixel 2 XL using Tapatalk Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 26, 2019 Share Posted September 26, 2019 Looks like everything is still together. That is actually the starter relay. I guess it could be a PDC as well, never really thought about that but it is grouped with the relay center so it is a relay. Damn. Beat to the punch Link to comment Share on other sites More sharing options...
Dammerung Posted September 26, 2019 Share Posted September 26, 2019 Replacing battery cables and refreshing connections, one of the connectors snapped off where the small positive cable off the battery connects to a bolt. I can only find it's called the PDC, but can't find a replacement. Any ideas, photo attached If you’re talking about that unit, that’s the starter relay. You can get those at o’rileys for not that much. Replaced mine because I thought it was screwing around with my fuel pump.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
nknapp16 Posted September 26, 2019 Author Share Posted September 26, 2019 Thanks guys, thats the photo before the green wire thats at an angle decided to snap. Link to comment Share on other sites More sharing options...
