LTZ_3 Posted September 10, 2019 Posted September 10, 2019 My clutch master cylinder was at one point leaking on to my fuse pannel. I took it apart does not look bad some corrosion not much. The question is can it be cleaned or do I need a new fuse pannel? If it can be cleaned whats the best way?
Big Dan Posted September 10, 2019 Posted September 10, 2019 Depends on how bad everything is. Post a picture. If the clutch fluid didn't eat anything up and it's just oxidation, contact cleaner will help.Sent from my Pixel 2 XL using Tapatalk
Jeep Driver Posted September 14, 2019 Posted September 14, 2019 Your pics are showing the interior side of the bulkhead, not the fuse block. The fuse block separates from the bulkhead. Yes, that can be cleaned. Fuse block can be obtained from a similar year XJ.
