masimmons25 Posted September 1, 2019 Share Posted September 1, 2019 I'm looking for a set of tail lights with broken lenses. I am trying to come up with a way to produce reproduction or modified taillights for those of us that need a set and I want to be able to access under the lenses without destroying a set of good lights. Link to comment Share on other sites More sharing options...
saveevryjp1998 Posted September 2, 2019 Share Posted September 2, 2019 I've dissected several. I have housings and lenses. It's not near as easy as guys say. Techniques I've tried: Heat gun Hot bar Oven Boiling water Supposedely the composites are fused at factory around 210 degrees. The best way is still start out with 1 already starting to separate and use the water technique mixed with a heat gun and a ton of patients. Just a hair to much heat with any technique and things warp permanently. Link to comment Share on other sites More sharing options...
SatiricalHen Posted September 5, 2019 Share Posted September 5, 2019 I have one I know the housing is broken on, and I have one that has fire damage, but I don’t know if the housing is good or not. I can check if still interested. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
masimmons25 Posted September 6, 2019 Author Share Posted September 6, 2019 Passenger side in the process of being acquired, anyone have a drivers side? Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 6, 2019 Share Posted September 6, 2019 I may have a really messed up drivers side that I can give ya. Link to comment Share on other sites More sharing options...
