youngfred Posted August 31, 2019 Share Posted August 31, 2019 ... Going in to change the outside door weatherstripping window-sweeps, on both doors. They are both, old and cracked. Both window-regulators are hard to crank and dry with both not going down, all-of-the-way (before the crank gives). I am planning to grease both, while I have each side apart. I would like to grease them, only-once though. What is the best grease to use on the regulators and the cranks, that will not be too affected, by heat/cold, moisture, dirt(and-time) ? Thanks, youngfred Link to comment Share on other sites More sharing options...
kansashogan Posted August 31, 2019 Share Posted August 31, 2019 White lithium is what I used. I had to spray some silicone in the tracks when I replaced all the rubber parts in mine to make it easier to roll up and down. Link to comment Share on other sites More sharing options...
JMO413 Posted August 31, 2019 Share Posted August 31, 2019 I used white lithium also, works great. Link to comment Share on other sites More sharing options...
SVPete Posted September 1, 2019 Share Posted September 1, 2019 Since you are taking other things out, recommend you remove the regulators and pull the screw rod completely out. For some reason, the driver's side tends to have a worn spot and the passenger side looks like the bottom item in the photo. The good news, this internal piece is exactly the same as the manual regulators on four door Cherokee, front and rear. Also, if it is just a worn spot, you can swap this piece from driver's to passenger side. Don't know if it is the same on the power regulators. Always worth a look at the junkyard. Link to comment Share on other sites More sharing options...
