1J7GJ26S7ML566898
Ls2xjcomanche
*D4 TRIM STYLE D4 - VINYL BENCH SEAT
-SA CHARCOAL
173 Zone 73-San Francisco
1AA U.S. Dealer Retail
4AF American Coin Merchandising
4HA Special Scheduling Condition I
ADL Skid Plate Group
ALA SE Decor Group
APA Monotone Paint
BAF 130 Amp Alternator
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHN Command-Trac Part Time 4WD System
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRK Dana 44/226MM Rear Axle
DSA Anti-Spin Differential Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KWX EAGLE/SUMMIT DECALS BL
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAE California Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFB Front Heavy Duty Shock Absorbers
SGB Rear Heavy Duty Shock Absorbers
SUA Tilt Steering Column
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TRP 225/70R19.5G All Pos Traction Tires
TZA Goodyear Brand Tires
WJD 15X7.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA
Build To U.S. Mkt. Specifications
Build date:1/21/91
Body code:JL62
1 hour ago, Ls2xjcomanche said:
Our most Cali trucks not well optioned?
I don't know. That’s not an easy thing to call on. Just most trucks prior to 89 have some info missing on them and are not as detailed as post 89. It’s the Chrysler years that have the most detailed build sheets. But it seems like a well optioned truck.
  • 1 year later...
