JMO413 Posted May 26, 2019 Share Posted May 26, 2019 So it's not a Jeep but this is the only place I know to get real technical answers. I'm working on my mom's 1996 Geo Prism. There brake pedal goes straight to the floor and just barely work. My guess was master cylinder so I changed that. I bleed all four corners starting in the passenger rear. I vacuum bleed them first and got a full container full from each one. One of these full from each bleeder. The I did the normal pump and bleed with my wife in the car. The pedal feels good when the car is not running. When you start it the pedal goes to the floor still. If I unhook the vacuum from the booster the pedal doesn't drop to the floor. So do I replace the booster? I thought a bad booster would be a hard pedal. Any thoughts would be appreciated. Link to comment Share on other sites More sharing options...
jeeptec1 Posted May 26, 2019 Share Posted May 26, 2019 Failed master cylinder Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
JMO413 Posted May 26, 2019 Author Share Posted May 26, 2019 Brand new master cylinder that I bench bleed and got good fluid flow from. Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 26, 2019 Share Posted May 26, 2019 This is why I have always bled with the engine running........I want to know what's going on, how it feels, in it's working state. Sounds to me like a bad booster as you noted......but........you are there and I can only guess. Link to comment Share on other sites More sharing options...
JMO413 Posted May 26, 2019 Author Share Posted May 26, 2019 6 minutes ago, Jeep Driver said: This is why I have always bled with the engine running........I want to know what's going on, how it feels, in it's working state. Sounds to me like a bad booster as you noted......but........you are there and I can only guess. Thank you. Just looking for opinions. Got a booster coming. Hopefully that does it we will see. Link to comment Share on other sites More sharing options...
JMO413 Posted May 28, 2019 Author Share Posted May 28, 2019 Booster was bad guts were pushed out the front. Link to comment Share on other sites More sharing options...
