WTB- E-Brake pedal assembly that matches an 89 MJ...
Andy in Pa
I think someone modified the e-brake pedal assy in my MJ to allow the rear end to "drift out" on corners.  There are no increments in the pedal when you push it down, and it doesn't lock down either.  Anyone have one available?
Thanks,
Andy
  On 5/25/2019 at 10:37 PM, TheDude said:
Yours is missing the spring that holds the pawl onto the gear for the ratcheting mechanism.
Expand
Really?  Ok, I guess I need to go take a better look at it.  My 96 XJ crawler should be the same I would think.  Any clue if you can still get that spring?  I'll have to do some digging...  Thanks, that would be a MUCH easier fix!!!
It's hard to see unless you know. Search here on the forum or post on the tech page and someone can explain it better.
  • 1 month later...
