1J7FT26P4ML637072
gogmorgo
Build date of July surprises me a little that it's still a '91 but tenth digit M confirms it.
1991 Sportruck shortbed.
It was a manual trans, but engine and trans are gone. D30/35 are still there.
Built  7-91
Sitting at Wesman Salvage in Brandon MB. It's moved to a couple different spots in the yard but it's been there since the first time I was there almost seven years ago.
Interior's in decent shape. I pulled the rear cab panel and driver's side/middle seat belt buckle combo, woulda grabbed the other end of the middle too but my cheap T50 socket stripped the other bolt.
  • 3 weeks later...
*C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT
-SA CHARCOAL
125 Zone 25-Canada-Alberta
1AB Canada Dealer Retail
3N8 Drive Away Program Tracking
4HA Special Scheduling Condition I
ALA SE Decor Group
APA Monotone Paint
BAP 75 Amp Alternator
BCC Dual 730 Amp Maint Free Batteries
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CUM Mini Floor Console
DBB All Manual Transmissions
DCK 4SPD MANUAL TRANS - AISIN SEIKI
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EPE Engine - 2.5L Power Tech I-4 Cyl.
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JDB 180 KPH Primary Speedometer
K3Z STRIPE/BADGE/MOLDING/COLOR
KDN
KWS STRIPE/BADGE/MOLDING/COLOR
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
LMK Daytime Running Headlamps, High Beam
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
NHK Engine Block Heater
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
TZH Michelin Brand Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAC Build To Canada Mkt. Specifications
YGA Without Billable Fuel
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z56 Left Front Spring Group Vi
Z75 Right Front Spring Group V
Body model TL61
Build date 7-1-91
  • 1 year later...
