eaglescout526 Posted July 15, 2019 Share Posted July 15, 2019 1 minute ago, Minuit said: Geez, guess my '89 won't ever see cruise control in its life then. Ouch. I have a spare computer, wiring harness, servo, vacuum line to servo and some other pieces. The spare pieces I have was a kit and it was meant for '84-'86. I think the AMC salvage yard might have a few more pieces I can snag if you are set on installing cruise for your '89. Toughest thing to source will be the servo cable. Link to comment Share on other sites More sharing options...
Minuit Posted July 15, 2019 Author Share Posted July 15, 2019 10 minutes ago, eaglescout526 said: I have a spare computer, wiring harness, servo, vacuum line to servo and some other pieces. The spare pieces I have was a kit and it was meant for '84-'86. I think the AMC salvage yard might have a few more pieces I can snag if you are set on installing cruise for your '89. Toughest thing to source will be the servo cable. I'm not that concerned about it on that truck, certainly not yet. Control arm bushings that aren't rotten would be a good enough start on that one Link to comment Share on other sites More sharing options...
TexanEliminator Posted July 16, 2019 Share Posted July 16, 2019 I’m happy to report that I just scored the bracket, actuator, cable, and vacuum lie off a xj at the junk yard for $10! Just gotta find a stalk and my Comanche will have cruise control too! Link to comment Share on other sites More sharing options...
Minuit Posted July 16, 2019 Author Share Posted July 16, 2019 3 hours ago, TexanEliminator said: I’m happy to report that I just scored the bracket, actuator, cable, and vacuum lie off a xj at the junk yard for $10! Just gotta find a stalk and my Comanche will have cruise control too! Link to comment Share on other sites More sharing options...
TexanEliminator Posted September 9, 2019 Share Posted September 9, 2019 Finally got around to installing everything the other day. The stalk install was a PITA like I thought it would be but I got it done! Everything under the hood installed perfect but I was disappointed when I tried the cruise and it didn’t work. Ordered a new servo from teamcherokee.com and installed it today. It works perfect! Thanks Minuit for your write up! Link to comment Share on other sites More sharing options...
Minuit Posted September 10, 2019 Author Share Posted September 10, 2019 55 minutes ago, TexanEliminator said: Finally got around to installing everything the other day. The stalk install was a PITA like I thought it would be but I got it done! Everything under the hood installed perfect but I was disappointed when I tried the cruise and it didn’t work. Ordered a new servo from teamcherokee.com and installed it today. It works perfect! Thanks Minuit for your write up! BTW I have not forgotten about the floor mats. Working the hours I'm working now leaves little time for anything but posting on CC before and after work Link to comment Share on other sites More sharing options...
TexanEliminator Posted September 10, 2019 Share Posted September 10, 2019 12 hours ago, Minuit said: BTW I have not forgotten about the floor mats. Working the hours I'm working now leaves little time for anything but posting on CC before and after work Not a problem sir. Depending on when you get them ready to send will determine where I need them sent. Thankfully I'm about to leave Montana and head south back to Texas for the winter! Link to comment Share on other sites More sharing options...
Zelius Aurelius Posted January 26, 2024 Share Posted January 26, 2024 On 4/13/2019 at 4:49 PM, Minuit said: 1. What style of turn signal stalk did the MJs with factory cruise come with? I see two that look like they would fit. One is "fat" and kind of ugly, and one is skinnier like the regular stalks. I don't think it matters, but I'm just curious. Fat: https://www.amazon.com/ACDelco-19353957-Original-Equipment-Windshield/dp/B01NBIJ825/ref=sr_1_6?keywords=cruise+control+lever&qid=1555170339&s=gateway&sr=8-6 Skinny: https://www.amazon.com/ACDelco-19244690-Original-Equipment-Windshield/dp/B004JBJX8G/ref=sr_1_12?keywords=cruise+control+lever&qid=1555170309&s=gateway&sr=8-12 2. Here is a listing for a NOS actuator with the correct Mopar part number: https://www.ebay.com/itm/NEW-OUT-OF-BOX-OEM-Mopar-53007954-Cruise-Control-Actuator-Servo-91-96-Jeep-XJ/183250137613 If anyone could help me on what are the actual Part Numbers or links for the stalk and actuator? I have a 93 XJ and this looks to be pretty much all I need for an almost plug and play install. Extremely detailed and informative thread here, keep those trucks alive guys JV Link to comment Share on other sites More sharing options...
Zelius Aurelius Posted January 26, 2024 Share Posted January 26, 2024 Options for stalk: 1. (Already mentioned) https://www.amazon.com/ACDelco-19244690-Original-Equipment-Windshield/dp/B004JBJX8G/ref=sr_1_12?keywords=cruise+control+lever&qid=1555170309&s=gateway&sr=8-12 backed up by the following amazon review: or: https://teamgrandwagoneer.com/turn-signal-cruise-wiper-switch-gw-1986-1991/ Which seems to have a compatible OEM number 56000034 Secondly the actuator already listed by @Minuit at the start of this thread https://www.ebay.com/itm/NEW-OUT-OF-BOX-OEM-Mopar-53007954-Cruise-Control-Actuator-Servo-91-96-Jeep-XJ/183250137613 From my understanding these are the parts you need to get cruise control going on a 4.0 H.O.? Link to comment Share on other sites More sharing options...
