jpdriver1 Posted March 28, 2019 Share Posted March 28, 2019 In replacing the engine/trans in the 89, I've encountered a no crank situation. Found this connector under the underhood circuit breaker cover. any ideas --- please This was a 4.0L & ax-15 swap to replace the 4.0L & ba-10. Maybe for Auto trans? (not needed eh?) thanks Link to comment Share on other sites More sharing options...
Ωhm Posted March 28, 2019 Share Posted March 28, 2019 Looks like C109. Engine Harness to Engine Control Harness. Next to RH shock tower. Link to comment Share on other sites More sharing options...
jpdriver1 Posted March 29, 2019 Author Share Posted March 29, 2019 thanks Ohm -- will check in morning Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 29, 2019 Share Posted March 29, 2019 You should have a plug just like that going to the manual trans. 4 wires, plugs into separate harness. 2 wires for back up lights. 2 wires for 4X indicator lights. I suspect that is what that plug is. Link to comment Share on other sites More sharing options...
jpdriver1 Posted March 29, 2019 Author Share Posted March 29, 2019 will check that also -- thanks Jeep Driver Link to comment Share on other sites More sharing options...
