DeWManche Posted February 2, 2019 Share Posted February 2, 2019 Truck has 4.0 HO, 5 speed, 4X4, long bed, on 31s Currently has Dana 35 rear end. Picked up this 1992 Comanche around October 2017 for dirt cheap. It had a bad clunk, the seller thought it was the T-case. Towed it home and found it was just a broken motor mount causing the engine, trans and t-case to lean wich allowed the front drive shaft U-joint to smack the subframe. Some what easy fix and it’s been my daily ever since. Link to comment Share on other sites More sharing options...
DeWManche Posted February 2, 2019 Author Share Posted February 2, 2019 I’m in Washington state 98229 Link to comment Share on other sites More sharing options...
cody4359 Posted February 3, 2019 Share Posted February 3, 2019 Howdy, 98444Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
JMO413 Posted May 25, 2019 Share Posted May 25, 2019 *C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT -SA Charcoal 172 Zone 72-Portland 1AA U.S. Dealer Retail 25C Customer Preferred Package 25C 2TC Customer Preferred Package 2TC 3VN Customer Preferred Discount 4HA Special Scheduling Condition I 4M1 Retail to Bid Diversion Tracking 4UA SCA Tissue North America LLC ALA SE Decor Group APA Monotone Paint BAP 75 Amp Alternator BCC Dual 730 Amp Maint Free Batteries BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA HW1 JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KER KWR STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PE9 DARK CORDOVAN PEARL COAT PRI PNT - EE9 QE9 DARK CORDOVAN PEARL COAT SEC PNT - EE9 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBC Compact Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires TZA Goodyear Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group Body Model JL62 Build Date 2/3/92 Link to comment Share on other sites More sharing options...
jdog Posted January 31, 2021 Share Posted January 31, 2021 Selling Dealer: AMBASSADOR AUTO SERV INC Moscow, ID Link to comment Share on other sites More sharing options...
