I bought my 92 mj with a blown motor previous owner ran it dry of oil. I got a 96 xj on trade and was wondering if the engine would be a direct swap. Are all the sensors and everything the same?
I know for sure that the block will work for you  :L:   96 is the first year of OBD2 so I'm not sure on the sensors.
OBD2 is more useful if you're up to a complete wiring swap.  and being a 96 you can keep your dash and such.
The head and block should be the same as 92, the head is a different casting however the 96 production should still have the hole tapped for the temperature sensor on the head, later years have the spot for it untapped.
I think you’d have to swap most of your sensors . Other than that there Should only be minor issues like oil filter fitting being different and one or two minor things.
Sent from my iPhone using Tapatalk Pro
