Is a 96 xj and a 92 mj a direct motor swap?
The head and block should be the same as 92, the head is a different casting however the 96 production should still have the hole tapped for the temperature sensor on the head, later years have the spot for it untapped.
I think you’d have to swap most of your sensors . Other than that there Should only be minor issues like oil filter fitting being different and one or two minor things.
Sent from my iPhone using Tapatalk Pro
