stonehands Posted January 27, 2019 Share Posted January 27, 2019 Anyone done a dummy gauge cluster to a full gauge cluster swap? I have an 86 Comanche with the 2.5L Standard trans and want to do the cluster swap. I have a full gauge cluster in but not all the gauge work correctly. What needs changed out and how do you go about it? Oil Pressure Voltage Fuel Temp. My Tach is working believe it or not. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 27, 2019 Share Posted January 27, 2019 If you haven't done so yet, you will need to change the oil pressure switch to a sensor and the engine temp switch to a sensor. The switched just turn on an idiot light. The sensors send a signal to the gauge. The volt and fuel should work in either type of cluster. First make sure the cluster is good - not a fried circuit panel. Link to comment Share on other sites More sharing options...
stonehands Posted January 28, 2019 Author Share Posted January 28, 2019 I noticed both the temp and oil switches are single wire. Will the sensors be single wire as well? Thank you for your input. Link to comment Share on other sites More sharing options...
Minuit Posted January 28, 2019 Share Posted January 28, 2019 9 minutes ago, stonehands said: I noticed both the temp and oil switches are single wire. Will the sensors be single wire as well? Thank you for your input. Yep. Link to comment Share on other sites More sharing options...
stonehands Posted January 28, 2019 Author Share Posted January 28, 2019 Thank you both. Will be working on it this weekend. Link to comment Share on other sites More sharing options...
