I have a 91 cherokee sport minus the engine I got for parts . Are the front and rear differentials compatable with my 1988 Comanche?. Where do I check for the different ratios if theyre not?. Thanks
The front is a direct bolt in, the rear will have to have the spring perches moved and the shock mounts removed, but it is the same overall axle as an XJ
Ah, Pete beat me to it! Haha
Ideally the diffs have a tag bolted to one/two of the bolts on the pumpkin (thought I'd slip that in for Halloween) that have the ratio stamped on them.  If not opening the cover and the ratio is stamped on the ring.
If you decipher the ratio on the either diff you can pretty much count on the opposite axle being the same.  Then again there are certain stock configurations that come from the factory, stock.  someone (not me) knows those models/year/engine/ratios.  e.g. 88/d44/5 speed /BA-10/3.07  or 88/d35/AW4/3.55
