Bump stops... Now it has DW
4 minutes ago, Eagle said:
What did you use for control arms? Stock height or lifted?
Tried the ones that were prev installed on the jeep, and the ones that came with the new axle. both seemed to push it forward. I can only assume that it is stock height. I have not installed any lift as of currently.
I don't see any way the original control arms could push a different XJ/MJ/TJ axle 1 to 2 inches farther forward than the old axle. Something is very wrong.
How many shims are in the lower control arm frame pockets?
  • 3 weeks later...
On 10/22/2018 at 5:59 AM, Jeep Driver said:
Why is it up to 2" forward? and it sounds like the pinion angle is wrong.
Adjustable upper and lower arms?
Pinion/caster angle was wrong. You win.
I couldn't put the upper arms in because the bushings were shot. Had to press them out and press new ones.
Problem solved.
Seems like it's still about 1/2 to 1 in forward to me anyway..
LCAs are 15.25 center eye to eye aftermarket, unknown brand non-adjusable.
UCAs are stock
Strange thing DW is.
so before with the new front end I didnt put the UCA's in, I did not have dw at any speed pre or post hitting bumps/ruts etc.
UCA's are back on, with new busings on the axle. I can cruise down the road at any speed with no problem, but once i hit a decent bump, HOLY HELL.... hit the brakes and get it under 30mph.
first question, Caster angle. What is it suppose to be at if its "Correct"
Caster angle is 7 to 8 degrees, with 7-1/2 preferred.
Your new LCS are 1/2-inch shorter than factory, assuming Hornbrod's numbers are correct. If you didn't change the UCAs and you shortened the LCAs by a half inch, that reduced the caster angle. Adequate caster is important in resisting death wobble. Caster is increased by adding shims to the LCA pockets on the frame, but a half inch is a lot. You might need to get another set of lower control arms.
I'm surprised that anyone would be selling control arms that don't match the factory dimension pretty well. Where did you get yours?
[Edit to add] If you are using stock UCAs and shorter LCAs, there is simply no way your "new" axle can be sitting farther forward than your original axle, unless one of the axles had been modified to not sit in the correct location.
@Eagle They came with the axle when i picked up it. was prev installed on 97 cherokee.
I still have the factory ones, it seems like the set from factory is 15" and the "newer" ones are 15.5" roughly center eye to center eye.
my LCA's when i pulled them off didnt have any shimming at all in it?
I don't understand how shimming the LCA on frame side effects the caster angle though?
"edit" I get that, might just be a case of *Looks can be deceiving*) ill throw a pic later
The front axle setup is a parallelogram, with four hinge points -- two on the axle, and two on the frame. The upper and lower control arms are the horizontal legs.
The two vertical legs, on the frame and on the axle respectively, are fixed. Those dimensions won't change. If you don't change the upper control arm, it won't change (:duh:). So what happens if you replace the lower control arm with a shorter one? The only way it can go in is if you pull the lower hinge point on the axle closer to the frame. This rotates the entire axle assembly around the forward UCA mounting point. If the new LCA is shorter, the direction of axle rotation reduces caster. If the new LCA is longer, it increases caster angle.
That's how the factory addresses caster, but they do it from the aft end of the LCA by the use of shims in the LCA mounting pocket.
The LCA rear mounting holes ares slotted. When you add shims, it increases the length of the arms and increases the caster angle. The opposite when you remove shims. Thus you can adjust the caster angle angle with shims higher or lower, and also equalize the angle on both sides.
To elaborate on Hornbrod's answer: The openings in the frame pockets for the LCAs are slotted. The actual locating of the LCAs is accomplished by an insert called a "clevis," which has round holes and which has two studs coming off the back to anchor it in the frame pocket. When you adjust caster, you're not actually adjusting the LCA, you're shimming the clevis, which moves the LCA mounting hole forward or aft. [Part #5 in the diagram below.]
The shims do not go on the sides of the control arm. They go behind the lower control arm at the frame end, to push the control arm forward. Item #10 in Eagles' diagram.
Did you really drive it with out the upper control arms mounted, or did I read it wrong?
