Clutch master cylinder
Hello to you all
Newbie question here, sorry but my clutch master cylinder is wrong and I need a replacement,  the one I removed from the truck is the one in the first photo but all the replacements I've been able to find are like the one in the second catalog photo so I wonder if the new replacement will fit even if it's not exactly the same my truck had installed
Your advice is highly appreciated
Bolt Fit is not the problem. will your hydraulic clutch line screw in to the new one is the question. Not knowing the shape of your hydraulic clutch line. The factory one has a u shape turn at the end to fit in the top side of the master. If not you can always get the right one that fits.
