MJ-Alan Posted September 9, 2018 Share Posted September 9, 2018 Hello, my project 89 longbed 2.5 4x4 is coming along nicely but i need replacement lines between the fuel tank and the filler neck. i haven't had any luck with the local parts guys, all their fuel lines are much smaller than what i need. i found these on amazon but the reviews are mixed would anyone be able to tell me if these will fit on my 23.5 gal tank and if not i would really apreciate it if someone could point me in the right direction. thanks for the help - Alan https://www.amazon.com/Crown-Automotive-52000623-Fuel-Filler/dp/B009XV0B4M/ref=pd_bxgy_263_img_2?_encoding=UTF8&pd_rd_i=B009XV0B4M&pd_rd_r=203e7cae-b3d2-11e8-861c-cd06ea1130b1&pd_rd_w=X71jM&pd_rd_wg=ZokTs&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=6725dbd6-9917-451d-beba-16af7874e407&pf_rd_r=2C7W4F4W7G65E210SCSF&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=2C7W4F4W7G65E210SCSF#HLCXComparisonWidget_feature_div Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 9, 2018 Share Posted September 9, 2018 https://www.4wd.com/p/jeep-fuel-filler-hose-52100131ad/_/R-CNVX-52100131AD https://www.4wd.com/p/jeep-fuel-filler-vent-hose-52100132ab/_/R-CNVX-52100132AB Link to comment Share on other sites More sharing options...
Eagle Posted September 9, 2018 Share Posted September 9, 2018 Why are you looking at Cherokee hoses for a Comanche? They aren't the same. Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 9, 2018 Share Posted September 9, 2018 24 minutes ago, Eagle said: Why are you looking at Cherokee hoses for a Comanche? They aren't the same. SHOWING PARTS FOR YOUR 1988 Jeep Comanche Base Change Vehicle I know they don't exist. NLA. But according to you and Don parts grow on trees........so.........I figured I'd go to the parts tree and look. What you get when searching for parts for an MJ.........you get XJ parts. Shall I be a Debbie? OP, you are SOL. Ask here in the Wanted section after you get 10 posts............or........be creative, I love to be creative. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted September 9, 2018 Share Posted September 9, 2018 I couldn't find these 7-8 years ago, so I made my own out of bulk hose. Fitting it in at first, it formed a pretty good kink in the big hose, but I was able to push and pull and roll and cut and finally worked the kink out. The vent hose, 5/8" was easy. The bigger hose was not so simple, but it's worked for me for 7-8 years and is not kinked and does not leak. The guys at NAPA usually let me rummage around back in their hose department to find pre-bent hoses, some with double bends and fuel rated, might work if you can find angles that are at least close to that space between the filler neck and the tank. Then you can get creative. Link to comment Share on other sites More sharing options...
Big Dan Posted September 12, 2018 Share Posted September 12, 2018 On 9/8/2018 at 11:07 PM, Eagle said: Why are you looking at Cherokee hoses for a Comanche? They aren't the same. I used the XJ hoses and cut them to length. Link to comment Share on other sites More sharing options...
Dzimm Posted September 13, 2018 Share Posted September 13, 2018 If all else fails, buy a couple feet of the correct size hose from Napa and cut to length. They will kink slightly going over the frame rail but I have no filling issues with mine. Link to comment Share on other sites More sharing options...
