Jjscomanche Posted August 30, 2018 Posted August 30, 2018 Hey everyone, ive been working on my dads 1990 Jeep Comanche, and I just changed the radiator. I am trying to fill it back up with coolant, but it will not go down into the radiator from the reservoir. I turned the heat on, tried squeezing the hoses, and nothing is working. Please help.
yxmj Posted August 30, 2018 Posted August 30, 2018 Start by removing the top rad hose and fill it from there.....replace the hose....fill the coolent bottle and run it for a bit.....report back
Pete M Posted August 30, 2018 Posted August 30, 2018 and to bleed out the last bit of air in the engine block, get the back of the truck higher than the front, loosen the coolant temp sensor at the back/top of the head and use it to bleed out air carefully after someone else fires up the truck. and have a rag overtop the sensor as you do this because you might get sprayed. do not do this with a hot engine!
dwa175 Posted August 30, 2018 Posted August 30, 2018 take heater hose off at themostst fill till fluid comes out of heater hose you can also do this by taking off upper rad hose I found easler to take heater hose
Jjscomanche Posted August 31, 2018 Author Posted August 31, 2018 Filled it up from the top rad hose, that did the trick. Thank you all for the help👍
