gogmorgo Posted August 15, 2018 Share Posted August 15, 2018 1991 Sportruck (I'm guessing from the remnants of the squiggle stickers) 2.5L, ax-5, 2wd, 4.10 d35, SWB. Door sticker is AWOL, will attempt to learn build date through other means. Location is 60 miles from the hydrological top of North America. It's been parked, hopefully soon to have a small glitch with the paperwork solved so I can register it and get driving. Cloth bench seat (I'll get back to you on head rests), grey interior, pretty bare bones truck so nothing fancy. Current owner: yours truly. Link to comment Share on other sites More sharing options...
JMO413 Posted May 25, 2019 Share Posted May 25, 2019 *C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT -SA CHARCOAL 125 Zone 25-Canada-Alberta 1AB Canada Dealer Retail 3N8 Drive Away Program Tracking 4HC Special Scheduling Condition III ALA SE Decor Group APA Monotone Paint BAP 75 Amp Alternator BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMF 4.10 Rear Axle Ratio DRJ 175MM Rear Axle EPE Engine - 2.5L Power Tech I-4 Cyl. GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JDB 180 KPH Primary Speedometer K3Z STRIPE/BADGE/MOLDING/COLOR KDP STRIPE/BADGE/MOLDING COLOR KWA STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps LMK Daytime Running Headlamps, High Beam MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank NHK Engine Block Heater PB3 Intense Blue Pearl Coat QB3 Intense Blue Pearl Coat RA8 Delete Radio SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires TZH Michelin Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAC Build To Canada Mkt. Specifications YGA Without Billable Fuel Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z76 Right Front Spring Group VI Body Model TL61 Build Date 11/5/90 Link to comment Share on other sites More sharing options...
jdog Posted February 1, 2021 Share Posted February 1, 2021 Selling Dealer: MOUNTVIEW DODGE CHRYSLER LTD. North Vancouver, BC (CAN) Link to comment Share on other sites More sharing options...
