Could be a dumb question, but...
Here goes it: I have been told that Jeep did not offer the 'Laredo trim' on our Comanches. And since my Comanche does not have electric windows, that this one fact alone states, that it is not a Laredo. But my carfax states, that it is... so, did Jeep offer Laredo, in the Comanches? or not?
Info taken from online auto parts, can't say how accurate it is.
1987 Comanche 2.1L 126Cu. In. l4 DIESEL SOHC Turbocharged Laredo
    2.5L 150Cu. In. l4 GAS OHV Laredo
    4.0L 242Cu. In. l6 GAS OHV Laredo
1988 Comanche 2.5L 150Cu. In. l4 GAS OHV Laredo
I have the factory window sticker for my truck, the Laredo package is on there, they were most definitely an option from '87 on. I can also tell you that I'm pretty sure the Laredo package did not automatically get you power windows. Surprisingly it was mostly trim items, not necessarily convenience items.
Hard to answer since you have no signature and we don't know what you are driving. There are plenty of factory designated MJ Laredos w/o power windows. The best way to see what model and trim level you have is to run the VIN. if you post it up I can run it for you from a reliable site..
My VIN is under 87 registry, in my screen name and my profile has pictures of my Comanche.
Yes, it was offered, per the 1987 Jeep brochure:
According to the VIN you posted in the registry, 1JTML65T7HT020012, your rig is an 87 LWB Laredo.
VIN : 1JTML65T7HT020012
Country : United States
Manufacturer : Jeep Corporation
Vehicle Type : Truck
Engine :  1989, 6 Cyl. 4.2 Liter / 4.0L I-6 Cyl. MPI
Powertrain : 5-speed manual, floor gear shift, part time 4 W/D
Line (Body Type) : Jeep Comanche, 4-W/D Pickup, 7.0' bed, 120" wheel base
Model and Gross Vehicle Weight : 4001#-5000# : Comanche Laredo [1815/2268 Kg]
Check Digit : 7
Year : 1987
Plant Location : Toledo, Ohio, USA
Sequential Serial Number : 020012
Check Digit Test : VIN valide
Many thanks HOrnbrod!
Check Digit : 7
Year : 1987
^^^ What does all of that mean? ^^^
Sequential Serial Number?
18 minutes ago, RestoringNV said:
A 1987 truck, with a 1989 motor?
Saw that - it's a misprint for the motor year. Ran it on a couple of others, same info with the correct motor year. What's important is that it's a factory Laredo.  :L:
