86customanche Posted July 8, 2018 Share Posted July 8, 2018 (edited) I’ve got a squeaking noise that increases as the speed does. It’s not all the time but fairly consistent. Currently I only have 4x4 low gears available, and typically only ever use 1 and 2. The attached file is from an iPhone, now converted to mp3. Manche Squeak.mp3 Edited July 8, 2018 by 86customanche Usable file type Link to comment Share on other sites More sharing options...
86customanche Posted July 19, 2018 Author Share Posted July 19, 2018 I’m assuming others have listened to the audio, and am quite surprised there are no replies. The recording was made while driving, with no doors, and holding the phone near the driver door sill. Link to comment Share on other sites More sharing options...
SVPete Posted July 20, 2018 Share Posted July 20, 2018 A rock or something scratching on the brake disk? Brake pads worn? Something loose in the brake drum? Link to comment Share on other sites More sharing options...
NC Tom Posted July 20, 2018 Share Posted July 20, 2018 18 hours ago, SVPete said: A rock or something scratching on the brake disk? Brake pads worn? Something loose in the brake drum? Second this. Had a similar squeak. Shot front pads. Link to comment Share on other sites More sharing options...
86customanche Posted January 25, 2019 Author Share Posted January 25, 2019 It seems to have disappeared about the time I realized the tcase was dry. That was another issue solved by CC. I can now shift and the annoying squeaking is gone. Link to comment Share on other sites More sharing options...
Pete M Posted January 26, 2019 Share Posted January 26, 2019 dry!? that was a close call! Link to comment Share on other sites More sharing options...
