No voltage to fuel pump.
My 1988 4.0 automatic will not start. :hmm: I have spark. I have no voltage to the fuel pump when I checked at the connection comming from the engine compartment by the fuel tank with the key on.
No voltage at the ballast resister ether.
Which relay is the fuel pump relay? Location? :dunno: The schematics that I have are weak concerning the fuel pump :mad:
Anyone have a better diagram or schematic :redX:
Help!
Fuel pump relay is located on passenger's side inner fender in a bank of 3 or 4 relays usually under a plastic cover (unless removed). If you're standing along side the vehicle, it's the second from the right.
1st- Oxygen sensor heater relay
2nd- Fuel pump relay
3rd- Power latch relay
4th- A/C clutch relay
Google Renix manual, this has good information assuming your truck is 1990 or earlier.
