thejum57 Posted June 20, 2018 Share Posted June 20, 2018 I've tried everything I can think of but these 2 nuts will NOT budge, the other 6 came out pretty easily. Any suggestions? Link to comment Share on other sites More sharing options...
krustyballer16 Posted June 20, 2018 Share Posted June 20, 2018 I used a hammer and chisel once in a junk yard to break the nut up but the stud wasnt any good after that I just wanted the seat. If you can weld, don't worry about the stud...Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
jeeppapa Posted June 20, 2018 Share Posted June 20, 2018 I've tried everything I can think of but these 2 nuts will NOT budge, the other 6 came out pretty easily. Any suggestions? Try tightening it then backing it off. Try using trans fluid on it. I can’t tell from the pic but can you get a nut splitter on it. I’ve had to deal with those nuts many times and they can be a nightmare. Good luck88 Pioneer 4x4 auto LB D30/D44 88 Eliminator 4x2 5sp SB D35 Link to comment Share on other sites More sharing options...
coolwind57 Posted June 20, 2018 Share Posted June 20, 2018 You saturated them babies with some break-free first (or other penetrating oil), right? Link to comment Share on other sites More sharing options...
Dzimm Posted June 20, 2018 Share Posted June 20, 2018 Go the penetrating oil route first. If that doesn't work alone, try using a chisel and hammer to tap around the nut to help break it loose. If they won't come loose after that, you are pretty much stuck breaking them off. You can try heat but an open flame that close to carpet is not a good idea. Link to comment Share on other sites More sharing options...
