Cali Cruse Posted June 13, 2018 Posted June 13, 2018 MJ manual window regulators aren't made anymore, so naturally I'm curious if the Cherokee manual window regulator will work. If so, which year, and which online store carries it? Thanks.
johnj92131 Posted June 13, 2018 Posted June 13, 2018 Answer is yes. Cherokee 4 door is identical. Google will lead you to multiple purchase sources.
HOrnbrod Posted June 13, 2018 Posted June 13, 2018 7 hours ago, johnj92131 said: Answer is yes. Cherokee 4 door is identical. Google will lead you to multiple purchase sources. The only XJ/MJ manual window regulators available I've seen lately are in the junkyard. They are NLA new from any source, OEM or aftermarket, unless John knows something that I don't. Which is entirely possible...
Michael Buskirk Posted July 10, 2018 Posted July 10, 2018 I found some from an online parts vendor but they were expensive $160 each.
Crash Posted July 12, 2018 Posted July 12, 2018 If you asked this question 6,7 months ago. I had spare manual window doors. Now, I say good luck.
