1989 comanche mj Posted June 4, 2018 Posted June 4, 2018 My MJ needs rockers. The aftermarket ones are way off. I have a 4 door xj, they look the same, but of course longer and different at the back. Will the xj ones work assuming some fabbing at the back?
krustyballer16 Posted June 4, 2018 Posted June 4, 2018 Nope! Not even close and nobody makes good replacements. I've had to make all mine Sent from my SM-G892A using Tapatalk
kill_burst Posted June 6, 2018 Posted June 6, 2018 On 6/3/2018 at 9:32 PM, krustyballer16 said: Nope! Not even close and nobody makes good replacements. I've had to make all mine Sent from my SM-G892A using Tapatalk Very true, this is why I am replacing mine with 2x4 rock slider
Limeyjeeper Posted June 9, 2018 Posted June 9, 2018 The MJ rockers aren't straight they curve inwards. If you use XJ rockers you have to cut a strip out and reweld to get the curve
krustyballer16 Posted June 10, 2018 Posted June 10, 2018 The MJ rockers aren't straight they curve inwards. If you use XJ rockers you have to cut a strip out and reweld to get the curve You have to do this with all the repop "MJ" rockers too. Sent from my SM-G892A using Tapatalk
