Pete M Posted May 14, 2018 Share Posted May 14, 2018 need a rear driveshaft measurement, center of ujoint to center of ujoint. swb,_2.5,____ax5-ax4,______np231,___ d44= ________ d35= _________ Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 14, 2018 Share Posted May 14, 2018 Mine is NP207, Not sure if that will make a difference. Let me know if you want a measurement. Link to comment Share on other sites More sharing options...
Pete M Posted May 14, 2018 Author Share Posted May 14, 2018 absolutely! if it turns out to be any different than the 231, we'll make a new row for it. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 15, 2018 Share Posted May 15, 2018 Though, now that I think of it, the 207 wasnt ever offered in a shortbed. The only reason I have one in mine is because it was swapped from an 86. In 87 I think they went with the 231 only. Not sure how I got a driveshaft that fit to begin with. I ordered it from a junkyard online, and it sat for a few years before I could do the swap to 4wd. Ill measure it anyways, its probably one that was originally in a 231. Link to comment Share on other sites More sharing options...
Swampy Posted May 15, 2018 Share Posted May 15, 2018 Would an ax15/np231 work for your needs? I just have an 8.25 (essentially a d44) My rear driveshaft was 45" center to center after the soa in the rear Link to comment Share on other sites More sharing options...
Pete M Posted May 15, 2018 Author Share Posted May 15, 2018 3 hours ago, dasbulliwagen said: Though, now that I think of it, the 207 wasnt ever offered in a shortbed. The only reason I have one in mine is because it was swapped from an 86. In 87 I think they went with the 231 only. Not sure how I got a driveshaft that fit to begin with. I ordered it from a junkyard online, and it sat for a few years before I could do the swap to 4wd. Ill measure it anyways, its probably one that was originally in a 231. it is entirely possible that some real early 87s got the 207 if there were any left on the shelf. Link to comment Share on other sites More sharing options...
mnkyboy Posted May 16, 2018 Share Posted May 16, 2018 87 short box, 2.5l, AX4,231,D35 Link to comment Share on other sites More sharing options...
