For those of us that still love our 4 screaming squirrels, here is a little necessary upgrade/Egr Delete
The manifold I used was from a 2.5l yj ( a knock off pacesetter header from ebay)  Header Link and EGR Block off plate
There are going to have to be some modifications, the new mid pipe is shorter than the original, so you can either lengthen your new mid pipe or lengthen youe existing exhaust set up if you are going to reuse it
It is short about 1-1.5 ft, so it gives you the opportunity to run a new exhaust if you want
19 hours ago, Pete M said:
did you use the original crossover pipe?  it seems that it'd be too low.
Looks like Won Hung Lo got it wrong - again....  :laugh:
  • 3 weeks later...
It hung low because i hadnt fully tigthened the bolts before taking the picture. It was difficult to tigthen and hold a pipe that wants to fall on your face at the same time :rotfl2:
