zachbkr Posted May 8, 2018 Share Posted May 8, 2018 So recently I bought a 1987 2WD 2.5l Gas Comanche. The clutch was bad so I bought the Duralast clutch kit along with a new master cylinder and hydraulic hose. I dropped the trans and replaced everything but the union piece that connects the hose to the slave. While putting everything back together we had trouble with the union piece leaking. We eventually got it to stop leaking and it seemed like everything was working. I drove it home and let it sit for a bit and went to go drive it maybe an hour later and the clutch pedal stopped working again. Reservoir was empty and just leaking out of the bottom of the bell housing. My only guess is that we overtightened the union piece and messed up the line going into the slave, causing it to break open eventually. Any advice? Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 8, 2018 Share Posted May 8, 2018 I highly suggest going to an external bellhousing and slave found on the 94 and up models Link to comment Share on other sites More sharing options...
omega_rugal Posted May 8, 2018 Share Posted May 8, 2018 4 hours ago, Jeep Driver said: I highly suggest going to an external bellhousing and slave found on the 94 and up models he`s got the 2.5, so it`s a AX5 not AX15... Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 8, 2018 Share Posted May 8, 2018 27 minutes ago, omega_rugal said: he`s got the 2.5, so it`s a AX5 not AX15... Yes I was referring to his a ax5 Link to comment Share on other sites More sharing options...
88whitemanche Posted May 9, 2018 Share Posted May 9, 2018 On 5/8/2018 at 11:30 AM, Jeep Driver said: I highly suggest going to an external bellhousing and slave found on the 94 and up models This x2 Link to comment Share on other sites More sharing options...
