2 hours ago, Strokermjcomanche said:
There is no size difference from the 4.0 to the 4.7 because the internals are what makes a 4.0 a 4.7 .  Yes you can use the ax15 , the  clutch master cylinder bolts will need re drilled because the 86 holes will be sideways and the 87+ will be up and down .
Thank you how do you like the stroker?
https://www.ebay.com/itm/Bendix-12098-New-Clutch-Master-Cylinder-fits-Jeep-Cherokee-Comanche-Diesel-Turbo/110869183952?fits=Year%3A1986|Make%3AJeep|Model%3AComanche&epid=78915273&hash=item19d0517dd0:g:rGoAAOxyJs5RdL6q&vxp=mtr
Advance Adapters makes the adapter for this master to your existing line or you can use new BSS line.
You have options.
The above should be a decent master, US made, Bendix.
