agamble Posted April 21, 2018 Posted April 21, 2018 I am seeing if anyone has had this dilemma and if so how they were able to correct it. I have a sway bar bolt that won't come out. As you can see in the picture the portion the bolt threads into broke free of its welds and spins while attempting to loosen the bolt. I can't get anything in there with enough force to pinch it and loosen it out. Its smooth so I cannot put a wrench on it. The only solution that I can think of, and I don't want to do it, is cutting a section out of the box frame to try and tack it again.
DirtyComanche Posted April 21, 2018 Posted April 21, 2018 Grind the head off, punch it through, make or buy a tab nut or bolt and fish it in there.
