Omarmartinez33 Posted April 12, 2018 Share Posted April 12, 2018 I’m tired of spending money on this leaky 2.5 I got I fix one thing other leak occurs. Also the transmission leaks like crazy. I won’t give on this project so I need advice on which swap is better. I’ve seen some cheap engines in low mileage parts with transmissions as well. Should I stay with the MJ engines or go elsewhere? Link to comment Share on other sites More sharing options...
Pete M Posted April 12, 2018 Share Posted April 12, 2018 that is an odd reason to do an engine swap. how would you know that the replacement won't have some other even worse problem? where is the trans leaking from? Link to comment Share on other sites More sharing options...
Omarmartinez33 Posted April 12, 2018 Author Share Posted April 12, 2018 2 minutes ago, Pete M said: that is an odd reason to do an engine swap. how would you know that the replacement won't have some other even worse problem? where is the trans leaking from? From the bottom half of it but just tired of it lol. This is what I looked at http://www.lowmileageparts.com/1986-JEEP-COMANCHE-Engine-P304682.aspx#.Ws_RhRYpCEc Link to comment Share on other sites More sharing options...
Pete M Posted April 12, 2018 Share Posted April 12, 2018 you want to try and adapt a 2.8 v6 into your truck? wait, lemme rephrase that: you don't want to try and swap a 2.8 into your truck. any inline 4 2.5L block from any year XJ/MJ/TJ/YJ will work for you. no need to get drastic with the ancient engines when a late 90s will do fine. Link to comment Share on other sites More sharing options...
Omarmartinez33 Posted April 12, 2018 Author Share Posted April 12, 2018 10 minutes ago, Pete M said: you want to try and adapt a 2.8 v6 into your truck? wait, lemme rephrase that: you don't want to try and swap a 2.8 into your truck. any inline 4 2.5L block from any year XJ/MJ/TJ/YJ will work for you. no need to get drastic with the ancient engines when a late 90s will do fine. Ok I shouldn’t go to a v6 with those models though? Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 12, 2018 Share Posted April 12, 2018 That V6 is basically a downgrade from the 2.5l. The bigger GM V6 engines certainly have merit, but it is not as simple of a swap. Even with the added work of swapping a 4.0l in the 86 chassis, I think it's a good option to consider. Link to comment Share on other sites More sharing options...
Omarmartinez33 Posted April 12, 2018 Author Share Posted April 12, 2018 44 minutes ago, DirtyComanche said: That V6 is basically a downgrade from the 2.5l. The bigger GM V6 engines certainly have merit, but it is not as simple of a swap. Even with the added work of swapping a 4.0l in the 86 chassis, I think it's a good option to consider. What added work needs to be on the chassis? Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 13, 2018 Share Posted April 13, 2018 7 hours ago, Omarmartinez33 said: What added work needs to be on the chassis? The firewall needs to be modded, and the whole radiator support and front crossmember swapped over. And probably other things. If you search I think there's some writeups on doing it. Link to comment Share on other sites More sharing options...
Pete M Posted April 13, 2018 Share Posted April 13, 2018 the link in my sig should have a couple writeups on it. Link to comment Share on other sites More sharing options...
voecks1 Posted April 13, 2018 Share Posted April 13, 2018 15 hours ago, Omarmartinez33 said: Ok I shouldn’t go to a v6 with those models though? Stay with the 2.5 or 4.0 Link to comment Share on other sites More sharing options...
mjeff87 Posted April 13, 2018 Share Posted April 13, 2018 Where are you located? If you're anywhere reasonably close to southwest PA, I've got a complete '87 2.5L sitting in a barn up there. You can have it for free if you can get it. Jeff Link to comment Share on other sites More sharing options...
Omarmartinez33 Posted April 14, 2018 Author Share Posted April 14, 2018 On 4/13/2018 at 11:04 AM, mjeff87 said: Where are you located? If you're anywhere reasonably close to southwest PA, I've got a complete '87 2.5L sitting in a barn up there. You can have it for free if you can get it. Jeff Bet I’m in New Jersey Link to comment Share on other sites More sharing options...
