Hello Comanche World!
Owner of a 1991 Jeep Comanche Pioneer with a 5-speed manual here. I'm curious how come some Comanchees have a straight shifter and others have it angled. Is there a way to go from the angled to the straight kind?
Thanks.
Are you talking about a 5-speed with a floor shift, or an automatic with a column shift? For 5-speeds, the only MJ I've ever seen with a straight(-ish) shifter is my '88, and it's because it has a tranny and shifter out of a Wrangler.
My guess was that BA-10/5 trannys and AX-15 trannys has different shift levers due to the different heights of the shifter housing. The original lever from my 87 has an extra bend to it than the lever I pulled from a 90 XJ. I used my original lever on my NV3550 conversion and the angle of the shift knob is kinda awkward. I think removal of the shift lever is different for later years, but I removed the shifter housing, put the lower section in a vise, and used a punch to knock the lever off. I believe newer shifters have threaded holes in the sides that pull the inner bushing out to relieve some tension and make the process easier.
