omega_rugal Posted March 16, 2018 Posted March 16, 2018 not the way i wanted but i`m ready for summer.. i hope (old link wasn`t showing) stupid efan i wanted to install was too bulky to fit, even with the adde clearence but i had another that was burned, only a custom made adapter flange was neccesary btw it stalled hahah when i took the vid i was goign to shut it down so i closed the lpg, at this point is running on residual lpg...
HOrnbrod Posted March 16, 2018 Posted March 16, 2018 No shroud? W/o a shroud it's just a noisy ornament.
omega_rugal Posted March 16, 2018 Author Posted March 16, 2018 7 hours ago, HOrnbrod said: No shroud? W/o a shroud it's just a noisy ornament. i know, i`m working o it...
omega_rugal Posted March 17, 2018 Author Posted March 17, 2018 i don`t like it, it`s heavy and ugly...
JeepcoMJ Posted March 17, 2018 Posted March 17, 2018 ...you can't seriously think this isn't uglier than the stock one. Aside from that, it is an inefficient fan in comparison considering how large the hub is and how small the blades are.
HOrnbrod Posted March 17, 2018 Posted March 17, 2018 Yes, it works. It rotates, makes noise, and draws power. Might not provide much cooling for you come summer though..
omega_rugal Posted March 17, 2018 Author Posted March 17, 2018 we`ll see, summer here is brutal, if it works here, will work anywhere... it was 32 degrees today and signs of overheating, for the first time since i got the comanche...
HOrnbrod Posted March 17, 2018 Posted March 17, 2018 12 minutes ago, FrankTheDog said: Put two stock electric fans in it. Can't argue with that.
omega_rugal Posted March 17, 2018 Author Posted March 17, 2018 if i had them... the one it came with the truck... i don`t remember where i put it
