Darren Posted August 11, 2007 Share Posted August 11, 2007 In doing the ax-15 swap can i use the the bellhousing off a 93 ho on my 87? Link to comment Share on other sites More sharing options...
jeepthing07 Posted August 11, 2007 Share Posted August 11, 2007 yes Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 12, 2007 Share Posted August 12, 2007 since this topic seems to be answered I'm going to further the question. can you convert a pre-94 AX15 to external slave and if so how? pics? necessary parts list? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 12, 2007 Share Posted August 12, 2007 since this topic seems to be answered I'm going to further the question. can you convert a pre-94 AX15 to external slave and if so how? pics? necessary parts list? yes. parts list is; post-94 external slave bellhousing. slave cylinder clutch fluid line pressure plate for correct application. clutch. you can't convert an internal slave to an external slave without machine-work. Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 12, 2007 Share Posted August 12, 2007 what kind of machine work, what needs to happen? Link to comment Share on other sites More sharing options...
jeepthing07 Posted August 12, 2007 Share Posted August 12, 2007 bearing retainers are different on the trans internal/external Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 12, 2007 Share Posted August 12, 2007 you'd need to provision bolt holes at the bleeder valve hole for the slave cylinder, somehow build a pressure plate and throwout bearing assembly plus a pivot point for it to work in there, that would work with your 4.0 clutch... it could be done, but when external slave bellhousings and assemblies ARE available...well, it's just not worth it. it's a project I wouldn't bother with and I have full access to a machine shop and a friend who can weld aluminum for free... Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 12, 2007 Share Posted August 12, 2007 i wasnt planning on it since it isnt just a swap over parts thing. cause i figure ill replace most of the junk in there anyways when i swap it. Link to comment Share on other sites More sharing options...
