School me about lift kit ideas. I want a lift that can fit 32-35 tires(more towards 32). Are there any, reliable brands that you guys would recommend? I am trying to not spend much, but if it's worth it, I will spend a little over 1,000 (NOTHING over 2,000). I'm still new to Comanche's in general, meaning I don't know things like if it also has a unibody, and if you can use Cherokee lift kits on it. Are the Comanche's limited to suspension lift's like Cherokee's? Once again, I'm still relatively new so anything will help!:thanks:
Comanches are hybrids -- the cab is unibody, exactly like the Cherokee. The back has a somewhat conventional frame and the bad can be removed, but with the front being unibody that doesn't help any with respect to a lift. Cherokee lift kits work for the front, but not for the rear.
