Under the hood homelessness....
I am not totally sure about the wire.  Could be for the underhood light.
The vacuum connector on the air box goes to the vacuum harness in the lower right corner of the picture.  However, it looks like most of the vacuum lines are not connected.
That wire is for the hood light
That vac line goes to the bottom front vac connector. Check cruiser54s hint and tricks for the part number to the new linesd6282c8537df1e16ab5ea0f9e1dee308.jpg
Sent from my SM-G900P using Tapatalk
