Swampy Posted January 8, 2018 Share Posted January 8, 2018 Hey guys, Just finished the ax15 swap on my 4banger comanche. I originally bought a prebled unit from rock auto. I bolted everything up and it worked great for all of about one pedal press. By the second pedal press the pedal went all the way to the floor and fluid was coming out of the bell housing. I took the dust cover off and I found the slave push rod and rubber boot in the bell housing, with fluid coming out of the slave. How should I go about fixing this? Another prebled unit? just replace the slave or fix the one I have now? Quote Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 8, 2018 Share Posted January 8, 2018 Do you have a photograph of the fork and throwout bearing and the bearing sleeve on the transmission another words the way you set it up before you put it in Quote Link to comment Share on other sites More sharing options...
88whitemanche Posted January 10, 2018 Share Posted January 10, 2018 Did it have the zip tie on it? Mine had the same issue but it needed the zip tie part to apply enough pressure to not shoot out it happened to me about 10 attempts till I realized it and gave in and bought a new slave cylinder (had a used unit) Quote Link to comment Share on other sites More sharing options...
Swampy Posted January 10, 2018 Author Share Posted January 10, 2018 On 1/8/2018 at 12:45 PM, Jeep Driver said: Do you have a photograph of the fork and throwout bearing and the bearing sleeve on the transmission another words the way you set it up before you put it in I do not have a picture unfortunately 58 minutes ago, 88whitemanche said: Did it have the zip tie on it? Mine had the same issue but it needed the zip tie part to apply enough pressure to not shoot out it happened to me about 10 attempts till I realized it and gave in and bought a new slave cylinder (had a used unit) It had it, but i cut them out before I installed it. I should just replace the slave? I have a slave from a 1996 xj, I'm not sure how it would come a part because I bout a pre bled system Quote Link to comment Share on other sites More sharing options...
88whitemanche Posted January 10, 2018 Share Posted January 10, 2018 Yeah the zip tie is there for that reason You might be able to finagle a way to apply abit of pressure to it like a rubber band or something but have you already pulled the parts out the trans tunnel? If the fluid bled out you’ll have to put everything back together and bleed it again Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
