kook911 Posted November 19, 2017 Share Posted November 19, 2017 Found out yesterday when I went wheeling the chain is loose as in it makes a horrible noise until it catches and then it works. So I know that I will need rebuild. Is there a master kit that is the go to for rebuilding these? Would it be better to pick up a used t-case and put it in the jeep and hope for the best. The mj is just my toy so it can be down for quite some time. I can pick up a used one for about $150 but it seems that I can also get the rebuild for about the same price. Link to comment Share on other sites More sharing options...
DirtyComanche Posted November 19, 2017 Share Posted November 19, 2017 It's often easier to just snag a lower mile tcase. However, that might not be terribly possible anymore. SKF makes a bearing/seal kit. It's decent. You need to get the correct one for whatever year your tcase is as the input bearing changed, IIRC. It might be worthwhile to snag some wide chain parts out of a 231C and get that chain if you want. Cloyes makes chains for all of them, IIRC, and Omix does for the J variants too (wouldn't risk it), and you can probably still get one from New Venture? Plus there's some eBay offshore options for even less (I'd do that before the Omix one, they're probably the same part). Link to comment Share on other sites More sharing options...
kook911 Posted November 19, 2017 Author Share Posted November 19, 2017 Found this one on eBay but don't know if it is any good or not. My main worried is buying someone else problem. Also looks like you can get the SKF and Cloyes chain from rock auto. https://www.ebay.com/itm/NP231-Transfer-Case-Rebuild-Bearing-Chain-Chevy-GMC-Dodge-87-2001-24MM-BK231D/322793060898?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D49453%26meid%3D874d2f942a294a86b1df8e0c29d9051b%26pid%3D100678%26rk%3D1%26rkt%3D15%26sd%3D322793060898&_trksid=p2481888.c100678.m3607&_trkparms=pageci%3A0d1bd33d-cd7e-11e7-bd2e-74dbd180048b%7Cparentrq%3Ad68700e915f0a866a47454d4fffa86b3%7Ciid%3A1 Link to comment Share on other sites More sharing options...
Tj1 Posted November 20, 2017 Share Posted November 20, 2017 Rebuild is fairly easy, even easier with the t-case on a bench. Theres a few different how to's on youtube that are great and easy to follow. Watched one from advance adapters to rebuild my Wranglers 231Sent from my SM-G900P using Tapatalk Link to comment Share on other sites More sharing options...
64 Cheyenne Posted November 22, 2017 Share Posted November 22, 2017 On 11/19/2017 at 3:13 PM, kook911 said: Found out yesterday when I went wheeling the chain is loose as in it makes a horrible noise until it catches and then it works. So I know that I will need rebuild. Is there a master kit that is the go to for rebuilding these? Would it be better to pick up a used t-case and put it in the jeep and hope for the best. The mj is just my toy so it can be down for quite some time. I can pick up a used one for about $150 but it seems that I can also get the rebuild for about the same price. Give it time.... before you know it, you'll have 3 MJs, a couple XJ donors, you'll be able to just go pull one from "stock".... Actually, I think If you look around, you should be able to find a decent used one for under a hundred bucks. Or your first whole donor for one or two hundred more.... Link to comment Share on other sites More sharing options...
kook911 Posted November 27, 2017 Author Share Posted November 27, 2017 Ended up opening my np231. Chain was definitely stretched. Once I got it cleaned up the back side of the case was wore into by the chain. Is this something that I need to replace or run it? Also when I spin the bearings they spin with no problems. Is there a way to tell if the bearing are shot? Link to comment Share on other sites More sharing options...
