youngfred's 91 Eliminator
Old post - a way to get rid of the rusty 2WD dust cap on your front Ravine wheels:
"There's another way if you don't want change knuckles (I didn't). You can't buy the OEM caps anymore, and there are no low profile caps; they will all stick through the hole somewhat. One solution I found is to use Mr. Gasket Chrome Dust Caps. They are just a tiny bit small, but you can cut a strip of aluminum from a beer can and fold it  around the inner lip of the hub for a shim and they will tap in firmly and stay forever.
http://www.summitracing.com/parts/mrg-2485/overview/
They look better than the original dust caps sticking through the hole.
Ah damnit, I forgot to mention those. Mine still look good after more than a year! Just make sure you make your ship thick enough that you have to pound the caps in. If you hit a bump and hear a faint "dink-dink-dinkadinkadinka" sound coming from outside you didn't make your shim big enough :laugh:
Expand
Yea thanks H,
I grabbed that post too, from Minuit's thread where he did the same thing and gave credit to,
as I kinda  recall - 'a chrome freak' maybe???, or some words to that effect. All meant, in a nice way, of course.
I don't quite recall the exact words but I thought about the photo above - instantly. :thumbsup:
Thanks again, I ordered a pair, earlier today.
I am sure glad to have joined this site and grateful for all of the help - all-y'all ( plural ), :brows:
have documented and continue to provide here.
youngfred
Expand
Thanks.
No worries,
I considered ordering two(2)sets originally, but then I re-set the bar
and convinced myself to get-em-done-right, the first time.
youngfred
Trying to remove the Retainers of the Lower Belt Trim Panels.
I don't want to remove the wrong way or break/crack anything.:brickwall:
Is there an easy way to remove these Retainers ?
It does say:
"Detach the retainer with a tool or carefully pull the panel and
screws out of the cab sheet metal." ???
Would that be a tool like the one used to remove door panels ?
Thanks
youngfred
  On 12/6/2017 at 6:17 AM, youngfred said:
Reworking my OEM Rear Step Bumper.
Will these work on the stock bumper ?
https://www.autozone.com/collision-body-parts-and-hardware/license-lamp-lens/dorman-license-lamp-lens/804803_4158_0?fromString=searchdone&make=&model=&year=
The listing says, 'no' but they kinda look like
they might ???
youngfred
Expand
One of the License Lamp Lens was cracked and
the connector socket was broken.
Ordered one to see if I could make it work.
Came in today(Amazon).
Looks like a (close-enough), direct replacement. :applause:
youngfred
  On 12/4/2017 at 5:50 PM, youngfred said:
Starting-in on the tailgate latch.
Looks like PO's were lefties/rightys(mostly) and one
(or two), middle-fingered dudes (some-of-the-time). :laugh:
youngfred
Expand
Dipped the handle for a couple of days.
Looking like it is gonna clean-up, okay.
youngfred
Good Day, today.
Temperature got up to - 70 Degrees.
Not bad for the second week in December.
Shooting-the-breeze, with the rooster and
'The Doctor', dropped by :
W.L. Weller - JustOnly-On-Ice/50 Swirls(no-stirring)
youngfred
Came across some Black Lug Nuts on ebay.
Humm... :shhh:
Wanted to see how they would work with the
Raised White Letters on the inside and the
front Dust Caps and the rear Center Caps,
painted black.
Photoshop changed it up a bit,
to more
of a - ying-yang-ish look.
Which I like :
youngfred
Floor Jack under the front end, with tires
just off, the-ground.
That's about what I am looking for.
Measured From - Ground to Bottom of Fender Flare
Right Now:
35" Rear
32 1/2" Front
Just hung the rear bumper back on.
Removed mostall of the - 'R-word'
and I left on, the matte-ty look.
Krusty's Hitch arrives today and I have
ever'thing ready. :banana:
"Any-way..."
(as my neighbor constantly says ???)
which I return with:
"Ab-so-lute-ly !!!"
We get-along real good.
* The most wasted of all days
is one without laughter. - e.e. cummings
youngfred
Got one more item to go on the BOM,
in order to finish putting together the
longer LSV rod.
The threaded-rod is 1ft long so I will be
cutting it down when I install the lock-nuts.
Thanks to Mr. H for his build suggestion below :
youngfred
Removed the rear trim panel with this :
The panels were held in-place by 'retainers'
which are the ribbed press-on interior screws.
This is how the interior looked when the truck first, came in.
youngfred
Starting in on the Headliner.
Gotta find another place to store
the coat hangers.:beerbang:
I-don't-know, but
I'm blaming this one on the PO. :brows:
'Peers-like someone tried to remove, before.
Speaker Grille was off and under the seat.
youngfred
