Amccutc21 Posted November 6, 2017 Posted November 6, 2017 I have seen some people on here with 3" leafs from hells creek and 3.5" RE coils. What else is needed to complete this lift? Also, is part number HC-9730 add-a-leaf or full spring packs? Are they 337 a piece or for the set? Would love to see some more pictures of this setup.
Dzimm Posted November 6, 2017 Posted November 6, 2017 What else besides leafs and coils? Required: - Shocks - Extended sway bar links (preferred) or sway bar drop brackets Highly Recommended: - Move brake line brackets or get extended brake lines - Adjustable track bar to correct side to side axle movement - Adjustable or longer lower control arms. (The Grand Cherokee LCAs would be a great option at 3" of lift, someone will chime in with what years, I don't remember). Remember to readjust your bump stops if you add bigger tires.
Pete M Posted November 6, 2017 Posted November 6, 2017 the WJ yeas, 99-04 have arms with a bend in them. should be a writeup in the link in my sig. if not, there should be. you'll need to get some alignment shims with them to cheat and make them "longer".
