Keyav8r Posted September 29, 2017 Share Posted September 29, 2017 As the title says - what LED bulbs are you using for tail, brake, turn, and back-up lights? Link to comment Share on other sites More sharing options...
Dzimm Posted September 29, 2017 Share Posted September 29, 2017 If you search for led replacements on Amazon for the bulb you need, you'll find something that would work. *bulb numbers for 96- bulb sockets* Below are what I use for my 97+ sockets. They are super bright and look great. The bulbs are the same for turn signals but they would require an in-line resistor to work or the flasher will think the bulb is out and flash rapidly. I myself just left the standard bulb as a turn signal for now. Taillights https://www.amazon.com/dp/B00HJEUUKU/ref=cm_sw_r_em_apa_lGAZzbKBH83DD Reverse lights https://www.amazon.com/dp/B00G2TV7OG/ref=cm_sw_r_em_apa_IHAZzbVT8C4FX Link to comment Share on other sites More sharing options...
cruiser54 Posted September 30, 2017 Share Posted September 30, 2017 www.onewaylight.com Link to comment Share on other sites More sharing options...
johnj92131 Posted September 30, 2017 Share Posted September 30, 2017 For backup lights I use these: For Headlights, I use TruckLite led head lamps. The make a big difference! No interior LEDs yet. But the page Cruser54 pointed to looks nice for an interior kit. Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 30, 2017 Share Posted September 30, 2017 I’ve been using the Walmart stocked led for the XJ, two different brands. I believe Sylvania is one of them, I use the led color matching the lenses color, in the XJ that is red led for brake light, amber turn and white reverse. All except the white led are very impressive far as improved visibility goes. The oem relay for the turn signal flasher went nuts about the difference, changed it to Novita EL12 Flasher and it’s worked fine so far.Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
